Question about iLO 3200 32 in. LCD Television
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
  • 7 more comments
  • Anonymous May 04, 2008
    ilo 32 hd tv stuck on one channel . bought a new remote and it will not work to change channels . the buttons on top will not change channels either ????
  • jsmith9982 Nov 06, 2008
    ILO-32HD none of the control on the remote or tv (except the on/off button) work. I can not change channels or modes.
  • clairboyant Nov 07, 2008
    I have the same problem of the tv stuck on one channel
  • bobstepp1 Nov 12, 2008
    tv stuck on one channel. Tried new bateries and a new cable company provided remote. Can not even change mauely on the set. All other functions work.
  • wright5274 Dec 01, 2008
    my tv will turn on and off but cant change chanels with remote or manual
  • jamaica4u69 Dec 04, 2008
    my tv stuck on one channel
  • zxoomer Dec 07, 2008
    i have the same problem. the tv is stuck on one channel. i turn it on and off, i removed the cable and reconnected it, i got a universal remote, nothing worked.
  • viewwin8 Dec 08, 2008
    I have the ILO-32HD but it is stuck on only one Input. You can not change channels, input or volume. The only buttons that work are the on off buttons on the remote and on the TV. Whould replacing the Key controller fix this?
  • gatordog Dec 11, 2008
    my 32 inch lcd tv is stuck on one channel it turns on and off what board needs replaced
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
Posted on Nov 19, 2008
  • Sherry Smith
    Sherry Smith Apr 16, 2018
    Thanks that worked but I had to unplug all the cords that was connected into the antenna box!
Same thing happened on my Samsung 32". i also removed the cable from the back. it seemed to be getting stuck on one channel in particular (which I don't watch), so what I did was go into the channel menu and DELETE the channel. Now, when I am clicking on the remote, it will bypass the particular channel.
I think the problem actually has to do with the microprocessor for the TV crashing when it is buffering too many channel input commands.
Posted on Jan 21, 2009
More info on my repair I believe there some type of signal in the new digital program for the next year that the TV simple don't read right and shout down the TV or get stuck, why y believe that simple because with air antenna there is no problem at all, but if I connect cable and I do the automatic set-up It will turn of or get stuck in the other hand if I do the look (of Channel's) manually I will have no problem till' you find a specific channel that it turn the TV of specifically on the 90" and up.(all this if you don't use a cable box)
My best
Posted on Nov 21, 2008
Power board
Posted on Dec 01, 2008
    Problem Solver:
  • 13 Answers
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: which part number is the control board for the iLO HD2600 ?
I currently in the midst of a complaint I filed with the BBB on this company. I am hoping that this may actually lead to a satisfactory result but I will have to wait and see. I encourage others to file against this company as well. I do not understand how a company can get away with such a poor quality product and even poorer customer service.
Posted on Jun 22, 2008
My TV sems "stuck on a channel" and it iwll not move up or down and it is not responding ot either the tv controls or the remote. It is Sharp LC-32SB24U TV
Tries Unplug the tv and all devices to this tv.Replug it back about an hour later.Than goto the tv menu.Go to PICTURE go down to reset.It will reset the tv back to factory setting to the tv,everythings should work as before,not then ur tv manual control senor board or the Tuner board have problems,must be replaced to solved this.
Jul 05, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Changing channels
A common issue with this model is the control key board (the key input board that has the buttons on the cabinet of the TV).
This board can cause a lot of issue ,from changing channels by itself,to intermittent shut off, also sources cannot be switched or they switch by themselves.
The less common issues would be the remote eye or the main board.
If you give the full model number and the product code from your TV, I can give you the part numbers.
Apr 01, 2010 | LG 22LG30 22 in. LCD HDTV
My samsung lcd tv is lock on tv channels only
Check function buttons. One may be stuck. Disconnect the function switches from the switch board. If you can change inputs with the remote then replace switch board or switches. if not then replace the main board.
Mar 25, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung 40in tv
either the control panel board or the main board has a problem.probably channel change botton on control panel is stuck or shorted.
Dec 28, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
TV Changing Channels on It's Own
Are you changing channels with the remote? Try taking the battery out of the remote, its buttons might just be getting stuck? If, when changing the channel by hand, it persists, then it is an electrical problem, and you should contact LG to see about getting your unit replaced.
May 08, 2008 | LG 32LC7D Television
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
iLO 3200 32 in. LCD Television Logo
11,311 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
