Question about Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
Installed 2 new lamps, still no picture...
This is the second time the bulb has failed on my t.v. The first time was no issue, bought a new lamp, replaced it, and it worked. This time- lamp goes out, I purchase new lamp, installed, still didn't light-up, Toshiba replaced the lamp, installed new one and still not working. The red and green lights are still blinking together in 1 sec intervals. Any ideas? Toshiba isn't much help and the nearest tech center is 200 miles away. Thanks!
  • 2 more comments
  • powerringer May 03, 2008
    I don't think I hear a spark sound, but it does hum like it's charging up then no pic and the blinking lights. Is the ballast or light engine hard to replace? Where can I order those?
    Thanks-
  • Anonymous Jul 08, 2008
    oh boy do we ever have the same problem. under warrenty till aug but we have still no pic, gone thru 5 bulbs sent back waited for them to send out a new one and back and forth 5 times now had a service call replaced the ballast, service guy bulb worked but guess what he could not leave it as it was his private stock. so we had to go thru the parts people again so he fixed our tv but didnot fix it as he couldnot leave the bulb. two bulbs later and second service call is on for this week. three weeks with no tv. not happy at all. toshiba is no help at all.
  • Anonymous Mar 18, 2014
    the bulb went in it have search and found the right bulb KPR113 lamp rating 4.8v 0.75A the find power light goes on
  • Anonymous Apr 01, 2014
    lamp went out and replaced with new one still no pitchure
    Champion:
  • 453 Answers
I had the same problem , first ? do u hear any arching noise like spark on the back of u set , if u do thats the ballast , it need to be repleace , now if there is not a spark u may have a bad light engine , need to repleace engine
Posted on May 01, 2008
6ya staff
SOURCE:
Bulb or Ballast?
If your old lamp is still working fine and the new lamp is not, then you bought a defective lamp. Get your money back or exchange the lamp.
May 17, 2012 | Panasonic PT-52LCX66 Projection Television
Lamp failure in WD-52525
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Jun 15, 2009 | Televison & Video
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
TV turns on and off.
It is possible that the ballust assembly is causing the lamp to fail. You likely need to replaced the ballust with a new lamp because if the ballust is bad it has likely already damaged the lamp. If you have been handling the glass of the new lamps with your bare hands this could be the cause of the short lif as the oil from your hands will cause premature failure of the lamp.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
Dec 30, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television Logo
230 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
