Xerox DocuColor 12 Color Copier Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have error code 093-315. How do I fix, I shut the power off by the switch like it said but the error code keeps coming up when it reboots.
JMJr
Level 3:
Master:
  • Xerox Master 694 Answers
  • Posted on Jul 30, 2016
 JMJr
Xerox Master
Level 3:
Master:
Answers
694
Questions
0
Helped
166437
Points
2276
Fisher & Paykel DW60FC Series (Freestanding Dishwasher). Have fault F30 repeatedly, after rebooting mains power supply. Please help.
Question edited for a lot more clarity. Your 'Possess F&K DW60FC' does not exist! :>D
Question moved from Televisions category.
Rebooting is not the fix, it won't work until you fix the pumping out.
Fisher and Paykel dishwasher error codes f30 The F30 error code signifies that the flood switch on your machine has been activated. This indicates a problem with water drainage. This could be a one-off issue, or it could be a symptom of something deeper. For example, if the drain hose is bent or blocked, it could cause dishwasher problems like flooding.
How to Fix F30 Error on Fisher and Paykel Dishwasher
https://unitappliances.com.au > how-to-fix-f30-error-on-...
Search for:
My iphone 6 keeps rebooting, I've already done a hard reset several times and a safari clear history, no good
hi Vardi.
i know you have said you have done a reset but this is all i could find out.
To perform a hard reset, hold the power button and Home button (the circular button below the screen) at the same time until your iPhone screen goes blank and the Apple logo reappears. ... People were amazed when they'd come into the Apple Store and I'd quickly fix their deadiPhone with a hard reset.22 Sep 2017
Why Does My iPhone Keep Restarting? Here's The Fix!
https://www.payetteforward.com/why-does-my-iphone-keep-restarting-heres-the-fix/
Why does my iPhone keep restarting itself?If iPhone iPad Keeps Restarting Randomly. You can restart or force-restart youriPhone iPad to clean all processes, which may help you fix "keeps restarting" issue. To force restart one device, just press and hold both of the "Sleep" and "Home" buttons at the same time for 10 seconds until Apple logo appears on screen.
What do you do when an Iphone keeps turning on and off?To do so go to settings ? Cellular/Mobile ? Turn On/Off Mobile Data. RebootiPhone: To reboot your iPhone, hold the power button and home button simultaneously for a few seconds. The Apple logo will appear on the screen and your iPhone is rebooted.24 Mar 2014SOLVED: My iPhone keeps rebooting/shutting down by itself? - iFixithttps://www.ifixit.com/Answers/.../My+iPhone+keeps+rebooting-shutting+down+by+itse...Search for: What do you do when an Iphone keeps turning on and off?
or go to this link.
iphone 6 keeps rebooting Google Search
Error code 000002 0006
It's a high voltage error. The machine probably needs the fuser rebuilt.
You can temporarily clear the code in service mode.
(if you dont do it fast enough the screen will shut off, just reboot and try again.)
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit
copier...
function
clear
err
then push ok on the screen, after that reboot the machine from the main power switch and it should clear.
2answers
I gave xerox xc7225 error code 303-777 can you help me
Solutions for : Fault Code 303-777, 303.777.00: Power Lost Detected Related Fault Code: 303-777, 303.777.00 Solutions ranked by relevance:
  1. This Problem Requires Additional Assistance. Contact Support
We provide support to the greater California area.
Please contact your support provider for this issue.
If you do not have one you can contact us at 858 573 6300.
2answers
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
I had a problem start with error code E000-0120. I easily found this was an overheating problem. The room where the printer was located had gotten very hot, so I shut the printer off and left it until...
these means that thermistor still reports the temperature problem or that copier was memorised the error code and keep reporting it. Auto shut off is sign of fixing trouble.
To be sure if the thermistor or lamp is faulty, first try under service mode to clear the error.
If that doesnt help you you need to call service to locate problem in fixing section.
Procedure to clear error:
Clearing E000
1) Start service mode, and select 'FUSER' under 'FUNC'.
2) Press 'E000RLS'.
3) Turn off and then on the power switch.
SERVICE MODE:
1) Press the "*" key on the control panel.
2) Press "2" and "8" on the keypad at the same time.
3) Press the "*" key.
Hope that helps!
1helpful
Dell Inspiron 6400 shuts off at randomly
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
2answers
Computer keeps restarting...
it sounds like your hard drive is bad. You can buy a new hard drive or you can try SpinRite I love this program and has fixed so many issues.
you can find SpinRite here http://www.grc.com/sr/spinrite.htm
2answers
PC keeps on restarting
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
