I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
I have the same problem. I have the service manual as well and the part where the volume knob is KLN-1547/C-15. Part code 001154700. Did you try replacing that part?
Hi jzurca,
I am a Korg C15 owner and experience some problem too. Can sent me a copy of the service manual for my reference? My email [email protected] . Thanks. Philip
