SOURCE: Hey westinghouse ltv-32w1
The Power Supply for LTV-32W1 is listed below.
Westinghouse LTV-32W1 Replacement Power Supply Board
SOURCE: screen cracked on LTV-32w1
The LCD panel is no longer available for these sets. You better off replacing it now.
SOURCE: My Westinghouse 32
It can be the backlight inverter board is going out or the power supply that supplys the power to the inverter board is going out if what you mean by 'BLANK' no light on the screen. Look for bad capacitors in the power supply first it is easier to get to than the inverter board.
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not.
First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board.
Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board.
Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns.
Also rate me if you like this post.
Thanks.
