On average, washing machines use 19 gallons of water per load, and the average household runs between 5 and 6 loads per week. Based on those figures, most washers use up to 5,605 gallons of water annually. Front-load washers use an average of 12.5 gallons of water per load, while top-load washers average 19.6 gallons per load. Older top-load models manufactured decades ago use 40 or more gallons of water per load.
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
When set on large load, it will use close to 30 gallons of water. On the smallest load setting, it will use right around 20 gallons. This is what makes the new front load washers look so good. They average around 4 - 6 gallons per load. Have a great day.
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve(typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
