Hello, my JVC T.V. is acting up. it has a black box that appearers after the little channel box disappears. if I push the volume button, it goes away until the volume box disappears, but as soon as the volume box is gone, it comes back. could you help me? is there a way to restart or reset my T.V.?
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
My parent's JVC did this as well. It took us a little while to solve it (and through searching for how to fix it, found this post).
Using the JVC's remote control, we pushed the C.C. (closed caption) button and cycled to the "OFF" setting. That fixed it. Using the TV's front panel setting did not fix the issue, we had to use the remote control.
Note: the "text" CC setting re-displays the black box.
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Press Menu on the remote Press Up or Down, Ch + or C- to get to Closed Caption Press right side button or Vol+ and Mode will be highlighted Press right button or Vol+ until it says Off on the right hand side of the Menu Press exit and that should do it.
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
Hello...try to power off by the switch on front panel..instead of remote...then pwr up the tv and maybe it's ok...or maybe try text clock function on off..and be sure that you are in "tv" mode..so it isn't in "semitxt" mode...good luck ron
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
