Question about LG MU-42PM11 47 in. EDTV-Ready Plasma Television
My LG MU-42PM11 popped a fuse on the zsus board. I tryed replacing just the fuse but it just blew again. Will replacing the zsus boaed fix the problem or is there anything else that could be the problem? The tv had sound but no picture or menu.
  • mestrovich Sep 01, 2010
    Ok, I replaced the Z-sus board with a rebuilt unit bought off of e-bay. The TV worked great for about 5 days. On the sixth day, I noticed that there was some... static on the screen, like 1 white pixel for every square inch of the screen. It was like this for a few hours when the picture got real distorted/fuzzy, after about 1 min of this the same fuse that blew on the old Z-sus board blew on the rebuilt Z-sus board. So now im back at square one. The new Z-sus board has a 3 month warranty on it. Is it possible the rebuilt board is faulty or could the buffer board be bad?
  • 160 Answers
Hello again.
In case if you would replace fuse (it's one of two ceramic slow-burning fuses installed in holders next to each other) and it woudn't burn but TV still have no image - that means that both Z-Sus and Power Supply boards are bad. If fuse got blown again right away - usually indicates that Power Supply board still OK and does not need to be replaced.
Before go ahead and order Z-Sus board, visually check out narrow buffer board that attached to it. On other end of it you will see several flat ribbon cables that go into Plasma Panel. Make sure that you will not fined any cracked (exploded) microchips ot other electronic components or burn marks on it. Sometimes short in buffer board can cause Z-Sus short out as well. If everything looks fine - replacing just Z-Sus board would in 95% cases repair your TV.
Posted on Aug 19, 2010
  • russtash Sep 01, 2010
    OK. You have to check voltages that coming out of Power Supply Board and adjust them if necessary. They got names like: "Vs, Va, Vset, Vscan" etc. Each adjustable V have potentiometer on the Power Supply Board with appropriate label. There is also sticker somewhere on PDP (panel) that states correct Voltage values. You have to use multimeter to have read and adjust those using phillips screwdriver. Black probe of multimeter should be on Ground and red you can put on labeled test point or just directly into the plug with appropriate marking (every pin on every plug that comes out of Power Supply Board is marked).
    Most of the time if Va or Vs out of range - it creates that "static" looking white pixels on screen when TV is on. Those values also can change when TV is warmed up after appr. 30 minutes of use.
    Replace Z-sus once more and adjust Voltages after it fully warms up. If you will still have same problem - buffer boards or even panel itself could be bad.
    Remember - you are trying to quick fix something that takes years of practical work to learn. It's like you are trying to fly aircraft with no experience and even no instructor in cockpit. So - don't be too hard on yourself, give it another try and if it is not going to last - just save for new TV.
    And stay away from Plasma technology with your next purchase.
    Russ.
6ya staff
SOURCE:
No sound or picture
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
Mar 22, 2014 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Have sound but no picture
Zsus board can be the problem. check the fuse. zsus board is the one on the right side. if fuse is open replace board.
Jul 06, 2010 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Zenith zsus pop
Hello to all! Some of the time with LG type Y & Z sustain boards you must replace both the boards in order to completely the repair or but not always. Please feel free to message or call me if you need more help with your Zenith plasma TV. 1-503-432-9904 / pleasefixitdave@yahoo.com Ask for Dave! If you are reading this post and you need help with a plasma or LCD type TV give me a call!
Dec 20, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
LG 42PC3D ZSUS Board Location
the z sus board is the board thats on the right next to the right speaker looking at it from the back, and you can get it at ebay cheap.
Sep 26, 2008 | LG 42PC3D 42 in. Plasma Television
LG RU-42PX10 42 in. HDTV
Try to replace the YSUS board first. If not fix then try to replace the ZSUS board.
Good luck
Apr 20, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lg plasma 42PC3D no picture with sound
I know you already replaced the board, this is for future searchers. If you heard a popping sound, then the picture went out, there is a 32 pin Sanyo module that goes bad on the board. That's probably what caused the fuse to blow. Replace the module, then replace the fuse. The module is less than half the cost of a used board. Since this was a popular model TV, there are lots of replacement boards on the used market.
Mar 15, 2008 | LG 42PC3D 42 in. Plasma Television
LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Jan 02, 2008 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
My LG Plasma TV RU42PX10C
Hi all..i had the same problem with my 42 inch LG
rz42px11. its a faulty zsus board(Z sustain part no 6871QZH033A) the pop
sound was the fuse on the board blowing.not that hard to replace but be careful with the connector ribbons! got my replacement from
https://www.chsinteractive.co.uk/ £150....expensive,but probably cheaper than
calling someone out to fix it.
P.S i tried just to replace the fuse on the board T2AH 250v but it blew,i think the fact the fuse blows means the board is faulty..but you could try.
hope this helps someone.
Good Luck
Dec 21, 2007 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
LG MU-42PM11 47 in. EDTV-Ready Plasma Television Logo
557 people viewed this question
Ekse
RONALD CARTER JR
