You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf Here is a transcript: Storing Numbers for One-Touch Speed Dialing 1. Press SET and DATA REGISTRATION The display will show: DATA REGISTRATION 1 .SPEED DIAL SETUP 2. Press SET twice. The display will show: 1-TOUCH SPD DIAL 01 3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20. The display will show: 1-TOUCH SPD DIAL [1...7] • You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again. • If a number is already stored at the button you select, that number appears. • If the button you select is registered for Group Dialing, GROUP DIAL appears. 4. Press SET twice. Use the numeric buttons to enter the fax number you want to store. The display will show: TELEPHONE NUMBER TEL = • Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.) • If you want to clear a number or a mistaken entry, press CLEAR. • To enter a pause in the number, press PAUSE one or more times
