Now common on machine owned since new (purchased in UK, now resides in New Zealand....) that every 4-6 washes (particularly with heavier loads) the double red flashing water/drain lights interrupt cycle.... Normal routine is to drain filter plug and need to tip machine for water from system to drain, re-start on Spin cycle and clears..... Have tried running Vinegar on cycles to clear possible detergent build-up but has not solved..... Other maintenance options I can try...?
You'll have to check the drain pump assembly located inside
the bottom front panel of the unit. Take it out and clean it completely to
solve the issue. Hope this helps...please post back for further assistance.
There are a few options for purchasing second hand washing machine parts for a Kelvinator 600 top loader in New Zealand. Here are a few suggestions:
Trade Me: Trade Me is New Zealand's largest online marketplace and is a popular place to find second hand washing machine parts. You can search for Kelvinator 600 parts on the site and filter by condition (e.g. used) and location to find parts that are near you.
Appliance Parts Centre: Appliance Parts Centre is a New Zealand-based online retailer that sells new and used appliance parts. They may have the Kelvinator 600 parts you need in stock.
Second hand appliance stores: There are many stores throughout New Zealand that specialize in selling second hand appliances and parts. You can do a quick online search to find stores in your area that may have the parts you need.
Scrap yards: Some scrap yards may have washing machines or parts that you can salvage for your Kelvinator 600. You can check with local scrapyards to see if they have any washing machines or parts that they are willing to sell.
Before purchasing any second hand parts, be sure to double check that they are compatible with your specific model of Kelvinator 600.
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines.A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced.A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges.This is a repair of MODERATE difficulty.Just follow these steps: 1. Unplug the washer. 2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off. 3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way. 4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place. 5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer. 6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken. 7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free. 8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside. 9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub.Also remove the boot from the fill tube coming from the dispenser. 10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break. 11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop.Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place.If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube. 12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove. 13. Once the door boot is back in place, re-install the operator console and washer top. 14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
Hi Ekruijver.As I know USA electric standarts diffirent then New Zealand.Your machine should not be use in there unless if you purchase one of those step down transformer for it.That could not be inexpensive solution anyway.That can help.Please check this web site:http://www.tortech.com.au/category/595/ They might able to help you for this issue.OR MIELE NEW ZEALAND.Thanks.
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
If you are resident in UK, phone a very good supplier who has never let me down, and very cheap. Tell him Archie told you about him as normally he only sells to trade but often I recomend him. His name is Steve, and he will normall post items out.02476279856 good luck
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
TRY TO USE HIGH TEMPERATURE PROGRAME LIKE COTTON PROGRAM WITH 95 DEGREE WITHOUT ANY CLOTHES AND WAIT UNTILL IT FINISH PROGRAMM , DONOT BUT ANY TYPE OF SOAP
THIS LIKE PROGRAMM FOR SELF CLEANING.
I THINK IT WILL BE GOOD !
THANKS
