Panasonic Lumix DMC-LZ7 Digital Camera Logo
Posted on May 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sd card error
I had over 200 pictures on my memory card and when i went to put them on my computer I got a message that my memory card needs to be formated. Now it won't work in my camera or computer. What can I do to save my pictures?!
Mike McWhinney
Level 3:
  • Master 537 Answers
  • Posted on May 03, 2008
Mike McWhinney
Master
Level 3:
Answers
537
Questions
9
Helped
328984
Points
1551
Use a software to recover the cards contents. There are commercial utilities, or freeware ones. For a free one, try:
http://www.snapfiles.com/Freeware/system/fwdatarecovery.html
3helpful
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
3answers
Memory Stick Error
Try to get hold of a card reader and access the contents on the card.
Mar 05, 2008 • Cameras
1helpful
When trying to playback photos from SD Card, the message "cannot playback image" is displayed. Happens when using more than one SD card, which rules out that it is the SC card that isn't working.
which rules out that it is the SC card that isn\'t working Not necessarily, switching SD memory card from one camera to another without formatting isn't going to happen. If the SD card was new and not formatted in the camera that it's going to be used in then there could be a lot of different errors occurring. Also if pictures were downloaded from the memory card to the computer and the card not formatted this will cause a problem as well. If you have been deleting the pictures files then again this could be a problem the card needs to be formatted. Another IF is if you downloaded pictures from the computer to the SD card and then put it back in the camera without formatting then it's not going to acknowledge the card. If you formatted the SD card in the computer then it's not going to work or work properly in the camera. Picture files can go from the camera to the computer but not back again because the computer operating system and software is not compatible with the camera firmware. It all comes back to format the memory card in the camera you are using it in before taking pictures.
2helpful
2answers
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
13helpful
3answers
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
1helpful
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Memory card problem
wheather you check in computer repair shop is their any virus present in memory card? format your memory card! check virus is present in your computer or not! ?Try it!
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
"memory card error" on Canon PowerShot SD600 digital camera
we hadnt had any case like this before. i will try to research on your problem as this is the first time too that i have encountered such problem.
1helpful
2answers
Memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
