Contributor
- Posted on Aug 20, 2010
Re: Water seems to be leaking into the freezer before it...
Actually your evaporator drain is clogged, take your freezer back panel off. At the bottom there is a drain hole, stick a flat head screwdriver and see if there is something blocking the drain hole. You will have to defrost your fridge first. Good luck!
