What operating system did you use on your system.? is it better first to uninstall the driver installed on your unit & install it again, this may help to correct the problem with your device.
Thanks.
Initially, what could be suggested is to uninstall and delete all associated drivers. You may need to check likewise if the Logitech Momo Steering Wheel has multiple hidden instances. They could be found in your Device Manager, View, Show Hidden Devices. All should be removed/deleted/uninstalled. Thereafter, reboot and do a clean fresh re-install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May i add, can you please tell us the Operating system you are using, and likewise a complete info about the problem...
Thank you
Can you please give more details on your problem so that i can help you fix it.
Waiting for your reply
Please reinstall the drivers if the problem persists then visit the manufacture website and download the latest drivers
