Ogrady1428,
I would check the filter on the fan intake first. Remove it and carefully clean it with compressed air.If this does not resolve your problem then I would remove the lamp and inspect the switch in the vicinity of the door for problems. Be very careful reassembling the unit once the door is removed. The interlock swich must be positioned correctly or you will get an error message. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem and how to fix it.
Thanks for using FixYa and for the generous rating. We answer these questions for free.
hardrocko
Thermal sensor not working correctly..my be covered even if your warranty has expired. Call Mitsubishi......
