Jet 3 Ultra Power Chair Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing red light batt. fully charged - Jet 3 Ultra Power Chair
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Aug 22, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288762
Points
1801
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Red lights flashing roller not coming on
When the red light is flashing while connected to the charger means the battery is being charged, once fully charged the light turn from red to green without flashing. If the red light is flashing while being use means the battery is low and in need of charging.
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
9helpful
Charging red light flashing on and off have a new charger and still rd light flashing
Try this i tired it and it worked... If not you may needa new batt. Just plug the power cord into the craddle, not the usb. Then put the camera on the craddle and let the red light come on, but not long engough to let it flash. Repeat this like 10 - 12 times jsut putting it on for a couple seconds. This will boast the batt engough to let the camera software know that once you put it on the dock that is is suppost to charge! Good luck any other questionos you can email me at [email protected]
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
2helpful
2answers
Pronto 91 fully charged batt but only gey 3 flashes off red light
Batters won't hold charge and work properly it sat up for that long. replace batterys
1helpful
Wii remote is not responding and every time i press a button the lights flash, after the battery was fully charged. I put regular bateries and nothing, either.
you might have to re sync the remote to the consol again open the front cover with the wii on press the red sync button then press the red button inside the batt compartment on the remote you will have to have reg batts in the remote to do this then put the rechagable pack back in this might help ive had to do this a couple times
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
1helpful
2answers
I have a charging problem on my 89 camaro
So found the problem it was the seilnoid on the wasnt working properly store said good put it back hit with small hammer fired up so just replaced whole strarter now fires first time sounds awesome had lot of trouble tracking it down went threw new battery's thinking that was prOblem but was bad starter unit try this maybe will help u to
5helpful
4answers
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
