The link below should assist you in diagnosing the OE code. LG Help Library OE Error Code Top Load Washer LG
SOURCE: Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
SOURCE: I want to remove my LG Fuzzy Logic WF-T8018Tp
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: my toploader "fuzzy logic" 6.5kg
Hi.
If there is no spin, c licking noise before spin may come from a relay in control module, from lid switch motor, or from the fuzzy logic control unable to start drain pump. This last problem may occur because of residual water inside the machine tub.
You should run a diagnostic cycle. The procedure is explained in user manual. LG should use the following:
Press Spin and Temp. and Power buttons simultaneously to enter diag. mode.
At the end of the process you should get an error code that will tell you what the problem is. If there is a code already, then please let us know the code.
SOURCE: Hi i have a samsung
It is probably not 1e but IE meaning input error. There is no water entering the machine. Could be the water valve. just in case check the inlet filter at the inlet valve to see it isn't blocked. then you will need to call for service www.thewashingmachineman.webs.com
