Protron PLTV-37 37 in. LCD Television Logo
Posted on May 03, 2008
PROTRON STAND We have a protron 37in. mounted on wall. We lost the screws that attached the tv to stand. Does anyone know the size screws?
  • NIC0S Jun 09, 2008
    LOST SCREWS AND DONT KNOW THE SIZE..
QMED
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 10, 2008
QMED
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
57212
Points
9
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Can this TV be mounted on a wall? What size screws are needed to attached the TV to the bracket?
Yes, you just have to remove the stand first, the screws will be Metric M5 or M6 that you can get from HD or LOWES, the length will be depended on how thick the bracket is.
When you buy mounting bracket kits, it should come with a bag of screws for attaching the TV to the bracket.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
2answers
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
2answers
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Not wall mountable???
I have wall mounted my Protron. Here is a website that has a picture of this wallmount: http://shop4.outpost.com/product/5374318?site=sr:SEARCH:MAIN_RSLT_PG There is a metal plate screwed into the back (near the top) of the set. The wall mount attaches to the back of that metal plate. Only problem is, I can't remember if that metal plate came with the tv, or with the mount. This mount can swivel up, down, left or right up to 15 degrees. It worked well for us. If you don't go with this mount, make sure the one you decide to get can handle the weight, and has VESA compliant mounting points. One word of advice, save the screws (and label it), so if you ever decide to use the base again, you can find it. I'm learning that lesson the hard way.
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
