Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hunter 60" fan and light died and the receiver will not work. The remote has fresh batteries but the whole unit slowly stopped one day. Is there anything more than a new receiver that I would need? Could the motor(if there is one) be dead?
Anonymous
Level 3:
  • Master 2,926 Answers
  • Posted on Aug 21, 2010
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1004710
Points
9623
Inside the light/fan assembly is a controller for the remote functions. It is a small plastic box and these controller are known to fail, and when they do, the fan will not operate. It is possible for the motor to be bad, but this is a rare thing to happen. Replace the controller.
6answers
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Remote does not work at all - light comes on (with the switch) and the fan did work fine but then slowly the remote did not work - there is no chain and yes I replaced the remote battery twice- now it...
if hunter remote does not turn on fan. then problem with remote or the fan receiver. remote part # 85095-1. just type hunterfan.com in browser, and click support to find phone number for help. have a good day !!
2helpful
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
2helpful
Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
4helpful
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
1helpful
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
