SOURCE: lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
SOURCE: Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
