I tried the diagnostic test but it didn't work Maytag MAH6500AWW
to check the nF issue water lines are clear
Hi
Thanks for using FixYa. Error NF
means No Fill. The washer has tried to fill but was unsuccessful. NF indicates
No Flow. There is something that is interrupting the inbound flow
of water to the washer, either hot or cold. Sometimes this happens
when water service in the area is interrupted, creating an air pocket that
causing the water valve not to sense water.
Try running the diagnostic test by—
Please do rate the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hello & Welcome to FixYa
NF error in your Maytag is
displayed due to no fill condition, when the washer tries to fill but is unable
to nf is displayed. Please check the water inlet valve for any clogs and
obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any
other questions.
Kevin
Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It
