Then you should chaarge your battery and see if your alternator is good or bad. Hope this helps!!
Please rate and comment - Thank You
I assume that you mean that you can turn on the ignition, and all seems well until you try to crank the engine, then everything goes dead. If this is what you meant, then your problem is most likely a very weak battery. You could try to jump start the car. If the battery goes dead/weak again, you should check your charging system to ensure that is operating before replacing the battery.
