Guys Please help, As i called to Nokia Support center , Spoke to Floor Supervisor but no help , they are unable to handle this situation.
I have Nokia 6070 , with USB cable , unfortunately i have lost the CD.
Previously i was able to transfer the data , but after i lost the CD and change System i am unable to transfer the data.
I have downloaded and installed Nokia PC suite 7.1
After installation of PC suite i open managed network and checked to Serial connection.
As soon as i plugged the CA 42 cable to USB port i am getting pop up message from "Found new hardware" and it try to install the software USB to UART. and then no success.
ultimately got message unable to install the required software , your hardware is not working properly.
PC suite still shows no connection with Mobile.
Now Vice versa,
If I downloaded the Cable Network driver and install the CA42 driver first and then PC suite and then try to establish the connection i have same error message , no connection between PC Suite and mobile.
Please help , as i need to transfer important data.
Thanks
Alex Robinson
I am unable to see new messages on my nokia 5230 until i go into the message center manually. How can i correct the settings so i will have an indicator to inform of new message
It seems that changed the message center by mistake . You need to set the right message center back . Just go message settings and for message center . Message center is a number of the message center provided by your carrier . If you couldn't find any message center , then i advice you to call your carrier care center to get the best help .
I just had my 42pc3d picked up by a repair shop to fix a similar issue. Mine had a pink line though. My tv is over 2 years old and out of factory warranty, but I spoke to a supervisor and LG is warrantying it. If you call in and get an answer you dont agree with or like ask for a supervisor, they are the ones who make it happen. The people you get when you call in dont know squat......ask for a supervisor.......good luck
Well, reinstallation of the driver over and over again is certainly not an option. If this laptop has been to HP 10 times (omg) for service, this is way too much.
I used to work for an HP call centre. Call them once more. But this time, when you get a tech, explain the situation and history of this laptop and then ask to speak to a supervisor. And please, be calm, don't yell at the poor tech (he really does want to help) and when you speak to a supervisor, ask for a CASE MANAGER. Right when you demand to speak to a case manager, the supervisor is supposed to automatically escalate your issue to the highest authority, the case manager. The supervisor will tell you a case manager will call you in 24 to 48 hours. It may be on the third day, as sometimes they have been very busy if a major issue has occured that they are handling.
The case manager will call you and do everything he can to solve your issue to YOUR satisfaction. And since the laptop has been in repair 10 times (the unofficial HP rule is 3 times, then replace it!) speak with the case manager and get a replacement. You really should not only get a replacement for all the time and trouble you have had over this, but your replacement should be a newer model.
You will ned to contact your mobile provider for a PUK code. A PUK code is SIM specific. Nothing will be erased from your phone. IF you imput a code too many times incorrectly, it'll lock your phone completely. Then, you would need to contact NOKIA Call the Nokia Care Contact Center:
Telephone: 1-888-NOKIA-2U (1-888-665-4228)
TTY/TDD: 1-800-24-NOKIA (1-800-246-6542) To get the phone FLASHED, which will ERASAE everything. Please be careful! Good luck!
well..firstly..this is not the gateway operation at all. we are independent folks. perhaps there is a way to gain a footing with this situation. let me know.
