Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WML520---When washing light coloured clothing it comes out with black marks on & if rubbed will smudge this only happens occasionally ie i have just been on holiday & the first wash was terrible but then was ok. Washing machine is only 18 months old i have tried 90 degree wash with nothing in & also today i have bought Oust washing machine descaler to see if this helps,the rubber seal does look fine, can you hlep.
  • Hotpoint Master
  • 6,081 Answers
It might be grease from the bearings due to a failed seal.
Posted on Jun 26, 2017
Anonymous
SOURCE:
gittos73
peter gittos
  • 247 Answers
SOURCE: wf000 aquarius
if the drum moves slightly up and down then your bearings are in need of replacing u can also check this by going to the back and taking the little cover of in the centre of the back check around the centre of the spider wheel if there is a mucky water mark then they do need replacing this will cost from £90-£150 to replace love
Posted on Nov 13, 2008
Anonymous
  • 86 Answers
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
Posted on Dec 30, 2008
Anonymous
  • 29 Answers
SOURCE: stale water smell
This is a common problem. There is a build up of grime in the hidden crevices of the machine. To help resolve this problem, put a cup and a half of good dishwashing power in the machine and then place it on HOT full capacity. Then place fill the fabric softener with bleach. Run the unit half of the wash cycle and then stop it and allow it to soak for 15 minutes. Then allow it to finish the cycle. Repeat this process once a week for 3 weeks. Also you may want to stop using fabric softener if you are using it. The softener acts like a surfactant and adheres to the upper crevices of the machine. After a while bacteria starts to build. The bacteria varies in composition; but a very little known bacteria thrive in these humid areas and gives off the odor you described. The bacteria is commonly known as SRB’s. Here is some more information on this subject. http://www.nesc.wvu.edu/ndwc/articles/QandA/OTsp00_Q_A.pdf Best o Luck :?) DRRXR
Posted on Feb 13, 2009
Anonymous
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
Anonymous
SOURCE: Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Posted on Nov 15, 2009
My hotpoint aquarius will not spin
If the inlet cycle proceeds and then activated the wash after the water level is detected then the program cycle is intact. However if the second spin does not start, you need to check if there is voltage to the motor at this time , if not the control panel memory to the processor can be corrupt or the IC damaged.
Jul 03, 2012 | Hotpoint WML520 Washing Machine
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
How do I remove the powder draw from the aquarius wml520, please?
1. Extend the dispenser drawer until the stop is reached.
2. Press the locking tab located in the centre rear of the drawer and pull the drawer out.
Mar 19, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
141 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
