Panasonic PT-52LCX66 Projection Television Logo
Anonymous Posted on Aug 24, 2010
I installed a new lamp and cannot get the lamp pop up to reset. How do you reset the lamp counter? PT52LCX66
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Aug 24, 2010
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340384
Points
4062
Cary369,
I have a tip at http://www.fixya.com/support/r4534617-reset_lamp_timer_panasonic_dlp_tvs which should help solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
How do you reset the lamp hours on a Panasonic PT-61LCX66-K
There probably is a service manual you can find on line to help you with how to reset the lamp hours.
http://www.manualowl.com/m/Panasonic/PT52LCX66/Manual/289575
Pt52lcx66
i have a panasonic pt-52lcx66-ksnd i would like to know how to reset lamp timer?
1helpful
Need to reset the lamp timer on a Sonya POA-LMP24 projector
Attach the power cord to the projector and plug it into an electrical outlet. Turn the projector on and allow it to initialize.
Press the "Menu" button on the top of the projector. Use the left and right arrow buttons to move the red box pointer to the "Settings" icon.
Use the up and down arrow buttons to move the red box pointer to the "Lamp Counter" icon. Press the "Select" button.
A pop-up window will appear displaying the number of hours accumulated on the lamp. Below where the hours are displayed is the option to reset the counter. Select the "Reset" option and then select "Yes" to confirm. This will reset the lamp hours counter to zero and reset the indicator light.
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Hi I have a PT52LCX66 and it is a great tv but I had to change the lamp about 6 months ago and now it is very dim is the lamp bad again or is it time to buy a new tv
The Lamp u replaced probobly not a good lamp or been in the warehouse storage not in the right Temp.too hot or too cold.It shorten the life of the lamp.Replaced the lamp again,tv still good.
3helpful
Replaced lamp bulb on panasonic pt52lcx66, reset lamp hour meter and red light is still on. Any ideas?
Pull the lamp out and install again and reset with the orignal remote control. (not a universal)
1helpful
I NEED TO RESET LAMP TIMER PANASONIC PT52LCX66.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. Follow these steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
6helpful
Lamp light will not turn off after installing a new one.
you might have to reset the lamp counter in order to get the indicator light to turn off, there are several websites than describe the procedure, the one i'm looking at is fixyourdlp.com/2007/11/29/reset-your-zenth-or-lg-dlp-tv-lamp-counter/good luck!
10helpful
I've already replaced the bulb on my Panasonic television model number PT52LCX66, but I can not get the message of the screen that tells me to reset the hour meter lamp. How do I reset the the hour meter...
Turn off tv. Hold vol- on tv and tv/video button on remote same time for 5 seconds. Select lamp time use vol- on remote to reset to zero. turn off tv to remove serv menu.
6helpful
2answers
Z44SZ80/Z52SZ80 | DLP PROJECTION service codes
1. Press and hold the MENU button on the TV.
2. Press and hold the MENU button on the REMOTE
(Hold both until the service menu pops up)
3. Press and hold the ENTER button on the TV
4. Press and hold the MUTE button on the REMOTE
(Hold both until the LAMP LIFE HOURS appears on the screen)
5. To reset the lamp counter and turn off the orange light press select on the REMOTE.
6. Press Select again to con firm the operation.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
