Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
Posted on May 05, 2008
Red power light flashing on and off
My camcorder has been fine until recently. Now when I turn it on to "camera", the red power light stays on for 3-4 seconds and then starts flashing on and off. It will record for the 3-4 seconds that the red power light stays on consistently, but when the red power light begins flashing on and off, it will no longer record. Also, when the light is on, the LCD displays the word "index"...I have never seen this before. It stops recording when the "index" word disappears.
  • 2 more comments
  • amehring Sep 24, 2008
    My camcorder just started doing the same thing. I would love to find out how to fix this.
  • Anonymous Oct 06, 2008
    I have the same problem too - called customer service - said power supply problem will cost ~200 plus shipping :(.
    Any cheaper way to fix it?
  • Anonymous Dec 20, 2008
    I have the same problem...started with the VCR mode...won't play or rewind or FW tapes, but for a few seconds, light flashes...nothing...same thing in record mode
  • mandru214 Dec 21, 2008
    I am having the same problem. The power light flashes in VCR mode and record mode. I have noticed though, if there is no mini DV tape in there, that you can put it in picture mode and it won't flash. Has anyone else noticed this?
A
Anonymous
The same thing happens to me! idk how to fix it
Can't take picture or record video?
Try turning the screen all the way around and close the screen so the screen its left outside where you can see if that doesn't work you will need to replace the ribon that connects the screen to camcorder.
1helpful
Camera will not turn on, red light flashes once. Possibly because it has been overcharged.
Red light flashes denotes the problem. Single time flash of red light moves towards your battery need replacement. Replace the battery with new one and it will work fine again.
Thanks
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
7helpful
2answers
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
1helpful
2answers
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
2answers
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
2answers
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
4answers
Help with my Panasonic nv-ds1 camcorder ? ? ?
Its the tape is stuck or the mechanism is jammed or the small pan caps have started there demise of your camcorder.. Inside most camcorders there are small surface mounted capacitors made by panasonic and they all I say ALL will leak one day and when they do its not just the cap thats bad but if left unattended it will eat up the Printed curcuit traces on the pc board. Have the unit looked at right away by a camcorder expert and see if its too late to save the board. Good Luck
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
