Question about Frigidaire Washing Machines
My Front Loading Washer reads error code LOC when I try to turn it on. It will not let me turn it off. I can't find the error code in my owners manuel. The washer is only 1 1/2 years old. Any assistance would be very helpful.
After 30 minutes of searching the solution is in the dryer handbook, there is a control lock feature to stop anyone from starting or stopping the machines -washer or dryer - to activiate it press options and select buttons at same time till LOC appears, and to reverse it or turn it off, press options and select buttons for 10 seconds - the instructions here say only3 seconds and that did not work for me, but 10 did thankfully.
Posted on Aug 17, 2008
I had to hold the options and select buttons down at the same time about 3 seconds and bingo it works again
Posted on Aug 11, 2008
6ya staff
SOURCE:
I have a frigidaire front loading washer and when I try to start it, the error message reads "LOC"
Good Afternoon Friend, thank you for allowing me to assist you!
If you are getting an error code LOC on your Frigidaire washer, it usually means that your control panel is locked. Let's attempt pressing and holding OPTIONS and SELECT at the same time for about 10 seconds. This usually does the trick. If not, you may want to try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Thank you! - Z
Aug 29, 2014 | Frigidaire Washing Machines
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Affinity front loading washer error e56, what does this mean?
1) Read the owner manual and proceed section troubleshooting,this mean the motor, probably is defective and need replace.
2) Try to run the software diagnostic.and make the test 9 for solution or diagnostic.
3) or call some tech from company or another you know it
God bless you
Sep 26, 2012 | Frigidaire Washing Machines
When i turn it on loc comes on and i cant get it to work. i tried yesterday and it said pause then error
The control is locked as what "LOC" indicates. Press the Options and Select buttons simultaneously for 10 seconds or until "LOC" is no longer displayed. Pressing the same buttons for 10 seconds will lock the control. There is actually a padlock sign marking between these buttons to indicate that these buttons are used for locking and unlocking the control.
Sep 04, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My front loading washer shows a code Err Loc.
there could be 2 things wrong 1 the pump had failed or the brushes on the motor have failed can you send me the error code thanks
shaun
Jan 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Broken washer
your control is locked
read the manual on how to unlock it. let me know if it wont unlock.
Oct 24, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
