Washing Machines Logo
Posted on May 05, 2008
Maytag Legacy top load washer is SMOKING!
Okay... help. Our 4 year old Maytag Legacy top load washer is smoking and smells like burned rubber. It smells like when you burn a belt in a vacuum. Took the back apart and examined it - no burnt electronics... but the front is a pain to get off. Does anyone know of a problem like this occuring in this make and model.
Husband notes that this happens during the spin cycle.
  • 2 more comments
  • Msfixit2 May 07, 2008
    Have the same problem exactly!!!! Help!!! What's wrong? Took off back panel and opened the top but couldn't see anything wrong. Apparently something's wrong or there wouldn't have been smoke and the machine quit working.
  • terne Jun 19, 2008
    Same problem, smoke and squealing during the spin cycle. If I stop it while this is happening and try to spin the "basket" by hand it is really hard, almost impossible to do. I have turned the "basket" by hand in the past if the load had become unbalanced and it is usually very easy to turn. Please help!
  • Anonymous Oct 01, 2008
    this is a ******** website that is just trying to sell smelly washer product. There will only be answers to posts that smelly washer is the fix
  • Anonymous Mar 29, 2014
    smoke came out from loading chamber
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4508
Points
7
This is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
1helpful
2answers
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
1helpful
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
