I have a Konica Minolta Bizhub 250 and can no longer scan to e-mail because our outgoing (SMTP) server now requires authentication. Thank you very much AT&T... Does anyone know if i can configure the bizhub to authenticate outgoing scan messages?
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
I've looked through the manual and the "SMTP Authentication User Name" option is not there as it is shown in the manual.
I have PageScope Web Connection 1.1a on the device. I've spent hours looking for a way to upgrade the firmware or something but to no avail.
Only when scanning, the image is crooked or slightily rotated.
scan to e mail not possible. Machiones says to check log. How?
