Have you tried to "clean" the printerheads. You know like you would do with a normal printer. Sometimes the printheads go stucked with old ink(wich you cannot see on screen ofcorse)
So far, the only solution I have found is the following:
Once theLabel has been designed, click on the Bar Code Button, click on the Data Entrywindow, press the Tab key which will allow more Labels to appear on the IndexWindow to be printed. Click the Tab key to create as many labels are needed toappear on the page to be printed.
Note: TheCopies of Each Label setting on the File Print window will not work in Windows7.
The Copies ofSets of Labels prints the number of pages desired for that Label.
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
After you press print the window pops up with printing preferences, select preferences and tell the printer you are printing labels, it will allow more time for the label to reach the start position and start at the right place on the label sheet.
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
