Hi dchaz,
with the indulgence of bestdarngood...
Pls recheck how the "new hinge: was installed and/or if it matches exactly the old one As it may not have aligned properly, this mis alignment will cause the lid cover not to be seated properly and a sensor/switch sense this thus the error display.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
How to clear the "Check Original " error message?
Description:
This
error can occur if the document being sent or copied is not inserted
properly, fed incorrectly or is too long. Follow the troubleshooting
steps and recommendations listed below:
Before
placing the document(s) in the Automatic Document Feeder (ADF), verify
the error message "CHECK ORIGINAL" no longer is displayed on the LCD.
If the error message continues to appear on the display, unplug the
unit for 30 seconds and then plug it back in.
Let me know if you need any further help
Please don't forget to let me know your thoughts about my solution.
If your problem is fixed, please rate this solution as that is one of the biggest
aspects of how this website works and in order to receive any credit in
helping you, I need to be rated.
Otherwise, let me know if you have further questions and I would be glad to help.
Thank you
