The picture just cut off in the middle of watching a program. We've tried replacing the batteries in the remote. We've TRIED to turn the TV off and on on the set itself, but there is no response. My son turned flipped off the circuit breaker and we got it back for a couple minutes and it went out again. Now nothing works. The red indicator light for power just keeps blinking on and off.The picture just cut off in the middle of watching a program. We've tried replacing the batteries in the remote. We've TRIED to turn the TV off and on on the set itself, but there is no response. My son turned flipped off the circuit breaker and we got it back for a couple minutes and it went out again. Now nothing works. The red indicator light for power just keeps blinking on and off.
You can't post conmments that contain an email address.
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor.
Stargazer
same here
my power light blinks but there is no sound or picture.
I have the same problem. I turned it on and got the red flashing power indicator light and that is it.
