My laptop was working just fine yesterday afternoon. Last night, I turned it on and got white lines running the screen, the log on sound, and then a blank black screen. The battery is charged, and I tried turning it on while plugged in and unplugged from the wall. I tried using F8 for safe mode as well, and just get a blank screen. When I go to turn it off by pressing the power button, the blank screen goes away and I can see my desktop with all of my icons, and then it powers down. Any ideas?
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
I had the same problem , this is a factory error , no matter if your warranty expired hp will solve your problem.
Call 800-474-6836 and explain your problem and they will let you know.
Thanks.
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For other problems with this Notebook you can Click Here
Hmm this is the problem with either bios/video chip so better dont go on for spending money uselessly on trying to fix it better get the system board replaced
PLEASE CHECK THIS LINK FIRST. YOU MAY BE ELIGIBLE FOR EXTENDED WARRANTY SERVICE.
Same thing but I am sure it overheated because I left it on an oriental rug. The computer works because I went to a different monitor. The screen is wacked.
Ok same thing happened to me but I left it on some plush carpet so it was hot when I picked it up. I reloaded all the drivers for the on screen by hooking up a different monitor. Yes everything works but the screen.
Thanks everyone!! I appreciate it!
hp pavilion dv6000
i push the button to turn on and the screen flickers then goes black. it won't turn on when it's on battery power or plugged in to the wall.
