Apple iPhone Smartphone Logo
Posted on May 06, 2008
Apple Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call for Help
Just synced outlook contacts with my iphone and in my iphone contacts, it appears someone else's number for my "own number". how do i change that?
  • scottmx1x Jan 03, 2009
    My girlfriend and I have the iphone when i put mine on for the first time i used her sign on the computer now it has my phone on her sign on and my serial number n everything but not hers should i register her phone again and how do i do that
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 07, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
4957
Points
24
THe problem will be on your computer in your Outlook Contacts, look there for the problem, once you change it there re sync.
2answers
A simple to implement, reliable way to sync Outlook 2016 Contacts and Calendars with my iPhone 6? (iCloud was a nightmare)
There are about 50 (at the very least) apps in app store ( I use 'Easy Backup" that would allow you to scan your contacts on iphone and email backup file so you can import it (one way sync) to either Outlook or Icloud.
3answers
ICloud lock
Your iCloud and apple id is just the same. If the apple id/iCloud sync with the iPod is yours you can just simply reset the password by clicking the link below.
Apple My Apple ID
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
1helpful
3answers
Want to synchronize my Ipone 4s with gmail
Download google sync and that will sync contacts calendar and notes to outlook and when you sync with iTunes it should copy from outlook. You might have to select outlook as a source in iTunes though.
How do I backup my iPhone telephone numbers to Outlook Express?
Here is a way, hope it can help you.1.Connect your iPhone to the computer using the supplied USB cable and launch the iTunes application, if it does not launch automatically. iTunes displays your iPhone on the left panel under "Devices."
2.Click your iPhone on the iTunes panel and click the "Info" tab. Click "Sync contacts with" and select "Outlook."
3.Select "All Contacts" if you want to sync all the contacts from your iPhone to Outlook. If you want to select specific contacts, click "Selected groups" and place a check on the contacts you want to sync to Outlook.
4.Click "Apply" to sync your iPhone contacts to Outlook. Click the "Eject" button on the right panel and disconnect your phone from the computer. Close iTunes.
5.Launch Outlook and click the "Contacts" tab. You should see the imported iPhone contacts.Good luck.
2answers
How to sync outlook with my iphone without using itunes.
you have to use itunes. that is one problem with the iphone, its very dependent on itunes. so to sync your calendar, contacts, messages, or other files in the phone, you have to sync it with itunes.
2answers
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
2helpful
4answers
Sync Outlook Contacts & iPhone
When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
I had the folders moved in different groups as well but I am not sure that it made a difference.
Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
Oscar
3answers
MS outlook active sync
Well work computers have there own special software I cant help you threw here but what you can do is call Apple and they should walk you threw the steps.
1-800-MY-APPLE
Thank you, Apple Care Technical Support
New Apple iPhone 3G Coming This Friday!
13helpful
9answers
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
2answers
Sync outlook2000 with iphone
i'm not so sure about outlook2000 but outlook2007 works great with calender and contacts. just make sure it's selected in your iphone settings in itunes before syncing.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
