I have a Samsung bottom freezer top fridge RB215LASH. Water leaks from the inside back panel down under the crisper. The drain is not clogged. Their is no problem with the evaporator coils freezing...
OK, first there is only two ways water can be entering the fridge under any circumstances, one is through the Ice Maker feed line coming from your wall to the back of the fridge and into the ice maker. The other is from the ice trays themselves leaking or overflowing or the filter itself is leaking. Look at the side walls of your refrigerator, are there water streaks running down the side? Have you reset the ice maker since you did your repairs? Have you replaced the filter lately?
Usual Causes
If the water pressure is too high, the ice tray can over fill or water
can splash out. You can turn the supply shutoff valve to reduce the water
flow. See the diagram below. If the ice cube tray has residual pieces of ice in the bottom, remove
the pieces by pressing the reset button. You may have to do this several
times to clear all the ice out of the tray.
Get back to me and I know you provided a lot of information, but this is a inline water issue relating to the ice maker and not really thinking it could be anything else. So if you can give me more information about the form in which this happens, such as you find the water after the trays are filled or if this is a constant but minimal flow, large flow, we can concentrate our plan towards this are of the repairs and diagnosis. Look forward to hearing from you soon.
What is the module? I have this same problem where the water runs out into the freezer.
