Washing Machines Logo
Posted on Aug 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My maytag 3000 washer displays f70 - Washing Machines
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232197
Points
12714
Hi
Error code F70 means Control Unit Failure, no communication is detected between the control board & interface. You'll need to use a multimeter to check for the continuity between the Keypad and the control board. Inspect the wiring between the boards. Also check for any burnt component on the control board. You may need to replace the control board or user interface. To be sure whether the boards use a multimeter. Usually if the drum moves then user interface is bad else its the control board. hope this helps...
Daniel
1 Related Answer
Anonymous
  • 618 Answers
  • Posted on Nov 20, 2010
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Amana front load washer model num NFW7500VW00 CODE F70 WONT COME ON OR START
I have had a good look around and this seems to be a common problem with Maytag Amana etc machines.
Trying search Maytag f70 code and you will see.
It seems to be a faulty Control unit. Cause number 4 below seems to be what you have.
Here is one answer from a tech guy.
"The "F70" error code is indicating a loss of communication between the Central Control Unit (CCU) and the user's interface board on the right hand side of the console. The main top can be taken off by removing the screws along the back edge of the top. NOTE: Disconnect the power cord from the power source before removing the top.
Possible Causes/Procedure:
1.Check for continuity of the user interface harness
2.Check the wire harness connections at the user interface board and the Central Control Unit.
3.If the unit will run and rotate before the "F70" displays usually indicates the user interface board will need to be replaced.
4.If the unit will not run and rotate usually indicates the Central Control Unit will need to be replaced.
if you feel you cant do this you will need a technician to come and look at this. "
4helpful
F21 error on model mhwe300vw13 maytag 3000 it
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
9helpful
Maytag 3000 series washer f70 error code only the start button beeps three times and i checked the harness model number is mhwe300vw12
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
What is code f70? washer wont start.
According to the Whirlpool cabrio / oasis manual
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} (F70)
Overloaded
oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity.
• Open the door lid to clear display, remove excess laundry, then restart the cycle.
1helpful
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Top Washing Machines Experts
john h
