Televison & Video Logo
Posted on May 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power up problem
Hi ! I was told that my problem was with the power supply board. I have replaced it and the problem is still there. When I plug the TV in the AC outlet, a relay on the power supply board keeps clicking and two small surface mount red LEDs on the main board flash. This cycle repeats itself a few times and stop. At this point both the POWER and OPC lights on the front panel flash. I hope you can help.
Thank you.
Luc Perron
  • 3 more comments
  • norrep May 07, 2008
    The TV is a Sharp Aquos LC-52D64U
    Thank you for your reply !
  • norrep May 08, 2008
    If it could help you in any way I have the schematics for the Sharp LC-52D64U in PDF format. Is it possible to send them to you ?
    I am sending it to your yahoo address. Good luck!
    Please send me annother email address since it did not work with the one you gave me.
    Luc
  • dissidentt Mar 20, 2009
    When powered on there is no screen and the power light flashes twice for everytime the opc light flashes once.
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on May 07, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1722107
Points
23750
I will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
  • 2 more comments
  • Sonny Berry
    Sonny Berry May 07, 2008
    I am searching for info on that model so far I have found no service info what so ever other than it was produced in conjunction with Dell. I will contact you as soon as I can locate the service info or schematics.
  • Sonny Berry
    Sonny Berry May 08, 2008
    yes, you can send it to [email protected] and I will look it over and give you some help on it. If its over 10MB yahoo will block it, but if that happens let me know and I will post an alternate email address of where I work
  • Sonny Berry
    ok as soon as I get it I will look it over and contact you on what to look for in the power supply.
  • Sonny Berry
    you can send it to me at work [email protected]
1helpful
2answers
Hi plasma lg tv 42px4mvh-ta when i switch on it does's not switch on, i contacted technician the Guy told me that the main power supply board has a problem of suppling power how will you assist me
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Gateway GT4010 desktop pc powers up but NO VIDEO. I cleaned a massive amount of dust from the system and have checked every connection, cleared the cmos/bios, tried to power up with just the power supply...
Dust can be a massive cause of problems on a motherboard as it acts like a blanket causing components to overheat and sometimes conducts small amounts of electricity. Many boards on this condition are basically fried and need replacing. You could try a 24 pin power supply but i doubt that will make any difference as you have done everything to restore it.
Regards.
2answers
Have Protron PLTV-3250 TV and I was told the power supply board was bad. All indications concluded this was the problem. Replaced the power supply board (FSP194-3F01 power supply) and turned the TV on. ...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Philips 52PFL7422D/37 TV is $2200 piece of junk... cant believe it wont work (no picture no sound) after just over 2yrs... I use to get picture and sound when i played around with the on/off switch...
Yes,it is the power supply board problems.The power supply board,that board where the power a/c cord plug into it.U have all the tools,know basic eletronic and basic soldering?Yes,check the power supply board for those dying parts call capacitors.These capacitors that are dying,it alway will bulges up or puffing up on it tops.By checking the power supply boad and replaced all these dying capacitors,will solved ur tv powering up problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
2helpful
In 42"panasonic plasma tv, standby red light would flicker then rather than turning into green and starting tv, it would turn off. I called plasma tv repair center at sion and vashi, they said that in Y...
Tv having a power supply board problems,not giving the tv the right voltages anymore.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Dell tv model w2600 - sometimes th tv will not turn on. However if i unplug the electric plug and then replug it, the tv will eventually turn on again. I have been told the power supply could be the...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem. Take care....
2helpful
3answers
Poweredge 2600 power supplies in red
Possibly a power distribution board problem.
PDB requires replacement.
3answers
Will not turn on
I have the exact problem on the exact same model .
HELP ... I have been told it may be a problem with one
of the power supplies on board ??? is this a red herring ?
Sharp AR 337 won't turn on
if you are not getting any lights when you plug in and turn on power switch. These would be the steps I would follow, make sure on/off switch is functioning, 15 amp fuse is good or any fuse on power supply board, make sure power is coming out of power supply board. Power supply is the board with the power cord coming up to. Hope this helps. Should have a tech familiar with this machine check.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
