SOURCE: screen is now white with the text --download started--, emergency @ usb.
i dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at the bottom of that screen it says, boothlock version: a870:zd09.1. i can turn the phone on, but it goes directly to this screen. i cannot turn it off, i have to remove the battery. i also cannot call or text or even see anything other than this white screen. i cannot receive calls or text either. what is wrong?
SOURCE: my phone is stuck in USB download mode bootlock
Take out the battery to unfreeze it, then Menu>Settings>Phone Info>Software Update>Check New. Repeat the Menu etc step till it doesn't find any more new software -- it may have to update an update.
SOURCE: Samsung Jet Cell Phone is "dead"
if you its under warranty i dont think they will take it because of being wet but i would call them.. also i would take a hair dryer a try to dry it out very good once the mother board gets wet not a lot you can do.. i am sorry that i cant just tell you how to fix because realy nothing you can do..
Testimonial: "Thanks for that. Phone is alive but "dead" in appearance. Seems to be an issue with charging battery - down to 3V - water marker on Battery OK"
SOURCE: My hone got wet and i imeadiately removed the
i droped y samsung intesity in water a few weeks ago. it was able to call out but now the screen will only blink the verizon logo and at the moment it says useb download mode. Is there anyways that i can recover my data form the phone?
SOURCE: my samsung intensity has decided
Hold the * button at the bottom left when your at the main screen (with your background)
