Format the memory card. See page 84 of this manual.
SOURCE: FINEPIX Z2 under VISTA
You need download finepix viewer 5.4 updater for windows vista from the link below:
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.4
SOURCE: take best possible photos of
Do you have duplexer? try this site
download the user guide
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=110&prodTypeId=18972&prodSeriesId=84028
pls dnt 4get to rate this thanks
SOURCE: Deleted Photos
Im sorry to say that you will not be able to recover them anymore. Deleted pictures are still there UNLESS you take new pictures because the new pictures will take over the space of the oldpictures.
SOURCE: How do I delete multiple pictures from a Finepix
view pictures hit menu delete is first one hit menu down to all frames & delete! or format will do the same if you delete you should also format
SOURCE: I have fujifilm finepix s9600 and need the
when you connect your camera with the pc the camera will probably appear as a seperate drive on your computer. for example if you have a hard disk C: and a dvd driver named D: check to see if a new external disk appears as E: which will contain the folder of your pictures on your camera.
you can also check here
http://www.fujifilm.com/products/digital_cameras/s/finepix_s9600/index.html
Testimonial: "Thank you found it.. excellent service.."
