Question about Friedrich M36TCE Air Conditioner
Water on floor - Friedrich M36TCE Air Conditioner
    New Friend:
  • 14 Answers
The drain pipe in your wall mounted unit is probably clogged. Shut down the electricity, open the cover and look for a tray under the aluminum coil. the tray shoudl have a small pipe outdoors. Condensate is normal in an Air conditioner
Posted on Aug 30, 2010
  • 3,074 Answers
Drain is clogged
Anonymous
SOURCE:
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
How do i stop my water pipes from rattling
Secure water pipes to floor joists, install a water hammer arrester. Try securing pipes first, they should be secured at every other floor joist. If you can't get to floor joists try a water hammer arrester.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 18, 2014 | Plumbing
Major water leak when it rains, water runs down driver side floor
Keep looking by covering area at hood etc and running water on the vehicle to locate where it is coming in---Windshield?
This is the best way if you cannot trace the stains from water to source.
Dec 10, 2012 | 1999 Ford Explorer
A/c leaking water passenger floor
Usually a sign of a plugged drain tube.
The HVAC box has a tube that drains the water onto the ground.
The tube should be at the bottom of the firewall near the passenger floor.
Jul 24, 2012 | 2002 Nissan Sentra
Have a 2008 Saturn aura. Water leaking on back passenger floor board. Was told that it could be clogged which was causing water leak. Took it to the shop, they said its not clogged. They said its the...
problem solved water in floor in drive floor an behind driver floor rear seat floor water in door drain holes was stopped up in door rain filled door up and over flow thru the panel into the floor of the car check by shake the door and see if u hear water that the problem drain holes is stopped up in the door poor design it also most under the weather stripping on the bottom of the door
Jul 19, 2012 | Cars & Trucks
2006 mustang water leaking rear floor
Hi , Its leaking water on the passenger rear floor? It could be the heater core leaking and running down the floor board to the rear of the vehical. Do you smell antifreez or see moisture build up on the windshield ? does the car seem more "humid" inside?
Jan 23, 2010 | 2000 Ford Mustang
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Is there a connection between a warm floor and a water heater?
Is the floor warm just in certain spots or all over. If just in a certain spot you may have a hot water line leaking in floor.
Feb 06, 2009 | Ruud Central System Air Conditioner
Open Questions:
Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. Heater won't turn on. Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. As best I can recollect, the sequence of events went like this: Furnace was working normally. Thermostat was set at 70. Turned temperature on thermostat down to 67 and left the apartment. Didn't notice if furnace was running or not at the time, nor if it was running and shut off when I lowered the temp. Came back an hour later. Furnace was running and temp was up to 72 degrees. Thermostat looked normal. No indication of low batteries. Tried turning the system off on the thermostat. Furnace continued to run. Nothing on the thermostat would affect the furnace. Eventually turned off the circuit breaker (for the apartment electrical, not the breaker on the furnace) to stop furnace. Waited. Turned breaker on. Furnace stayed off. Batteries failed in thermostat and screen went dark with barely readable failing battery message. Put in new batteries. Thermostat fired up but still wouldn't control the furnace. Switched to cooling. AC went on. Couldn't turn AC off. Had to turn breaker off again. Turned breaker on. Thermostat displayed "Wait" message when I tried turning on the furnace. Waited half an hour. Wait message disappeared. Still can't turn furnace on. Slid out lithium backup battery and slid back. Thermostat makes appropriate click sounds as if it is turning the furnace on or off, but furnace doesn't respond. Equipment Status screen shows furnace on or off depending on thermostat settings. Set thermostat to System Off. Checked breaker on side of furnace. Was off. Turned on. Turned temp up on thermostat. Thermostat clicked, but furnace did not go on.
Feb 15, 2020 | Carrier Heating & Cooling
See all Friedrich M36TCE Air Conditioner Questions
Friedrich M36TCE Air Conditioner Logo
87 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Dennis Boxerman
Felizardo Erilla
Felizardo Erilla
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
