See http://www.repairclinic.com/0078.asp#Duet for repair codes under Whirpool Duet
We had our utility room painted. When we brought the washer and hooked it by up , my rinse cycle won't rinse. I usually rinse on cool. I have a Kenmore 600 series
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on
the drive motor. If "Sud" is displayed a potential suds lock is detected. This may
signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
My washer flashes F and H. What does that mean
I've had the SUDS message--it means that the soap didn't rinse out completely. Sometimes if it does it mid-cycle, it will correct the problem itself. If it's at the end of the cycle, I usually just run a rinse cycle again. Recently I've been getting the F and H on the display--seems to be only in the rinse cycle. Any idea what that means?
My Whirpool Duet is flashing F H what does it mean?
