You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
Whirlpool top loader agitates when filling up
Nothing, I'm not sure what the problem could be because it does not happen all the time and when it does, it usually fixes itself. M# WTW57ESVW1
your water supply perhaps it is too low pressure ....
so the machine isnt filling fast enough
so check at the machine side of the cold water filler hoze
in the machine end is a filter cone
you need to carefully pull it out with flat nose pliers and clean it
if this doesnt fix it then perhaps the inlet valve is bad...
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
want to remove the agitator from my whirlpool 5132e washing machine
