sounds like the little pixels have burnt out. also go to the website of the place you got it from and type in the serial number it should come up with the tv you have.
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
I just fixed this very same problem. The capacitors are
the problem. However, I think that if you have some minimal skills with
soldering, you can fix this yourself. You just need to take out the
system board, then the power supply parts are on the top right. The bad
capacitor(s) will be bulging at the top and possibly have some brown
stuff coming out. The ones that go bad are 1000microfarad, 10V, however
you can replace them with higher voltage. I got 35V caps from radio
shack for 1.59 each. You just need to solder out the bad ones and then
put the new ones in and solder. Remember that the negative end goes on
the side with the bold black part of the circle on the system board.
Then just cut off the extra ends of the capacitors. If you are capable
of doing this yourself, you will spend at most 6 dollars instead of
however much a technician costs.
sounds like your lamp is needing to be replaced. www.alltvlamps.com will have the lamp for your set just enter the model number of your Tv to locate it.
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
