BOSS AUDIO SYSTEMS BV9155B Car Video Player Logo
Posted on Sep 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just installed the unit, reset it twice, and the DVD screen is not working, and is saying "WARNING: Please Stop Watch Video" What does that mean?
Anonymous
Level 2:
Scholar:
  • Expert 137 Answers
  • Posted on Sep 01, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
137
Questions
Helped
58126
Points
390
I do not know this specific unit, but it sounds like a safety device built into the unit so you cant watch the screen whilst driving.. it may be that you have ommitted a sensor wire or got a sensor wire reversed.
Re-check all your wiring and make sure that the ignition live and the battery live wires have not been reversed...
  • chivaro2003 Aug 19, 2011
    Also got this problem, you should ground the wire"park ***" something. If you do that iit will work right away.
  • George White
    George White Nov 06, 2017
    There is a wire that goes to your parking brake it has to be connected to a neg wire to bypass the safety feature..
7helpful
My new radio plays every thing but when i put a dvd it says warning please stop watch vedio player . you can hear the movie but there is no picture
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
8helpful
My dvd & usb is not working. Everytime i put a dvd in or try and use the usb a blue screen appears and says WARNING PLEASE STOP WATCH VIDEO PLAYER.
1helpful
Hello I have just acquired a LEGACY LD58MT the audio it works very well but when putting a movie in any format the screen puts on in black with a message that WARNING PLEASE STOP VIDEO WATCH PLAYER says...
This unit was not designed to be used while the car is in motion. Your parking brake must be in the engaged position in order to view the monitor. The brake wire must be hooked up to the parking brake wire or grounded in order for this function to work properly.
The parking brake on my xdvd8182 doesn't work, im thinking a broken wire. Ive tried the codes, grounding with a switch and hooking up to e brake
It is illegal and unsafe to watch the monitor while driving. I assume this is needed for an RV or something.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
52helpful
6answers
1helpful
2answers
Dual XDVD700
How to get code for xdvd 700
8helpful
2answers
Cant play dvd get warning msg please stop watch video play
yeah like everybody says CONNECT THAT Brake wire(could be any color depends on your Head Unit) with the BLACK WIRE...it works!!!!!!!
8helpful
13answers
Dual XDVD710 Car Video Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
6answers
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
