Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
