Question about Toshiba 37AV502U 37 in. LCD HDTV
What's the best alternative to a T6.3AH 250V Fuse in a situation one cannot get this?
  • ndueze Sep 03, 2010
    The fuse is on a Power Supply Board.
  • 132 Answers
Between 6.3 and 7 amps should be fine. what board is the fuse on?
Posted on Sep 02, 2010
6ya staff
SOURCE:
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
Sep 12, 2014 | Roland Cube Street - Battery Powered...
Fuse replacement
HI that is a fast blow and more safe circuit breaker.But before replacing it into a bigger value make sure to read the manufacturers recommended value of replacement fuse it is printed right at the PCboard at the place where the fuse is situated...
Apr 06, 2012 | Televison & Video
I CANNOT FIND A REPLACEMENT FUSE FOR THE VECTOR VEC024B INVERTER.i HAVE OWNED IT FOR LESS THEN 3 MONTHS . IS THERE AN ALTERNATE FUSE THAT CAN BE USED?tHIS IS THE CIGERETT LIGHTER CABLE FUSE. F8VL250V.
Go to any Appliance parts store with your fuse in hand and walk out with a replacement. The 250V fuse is AC OUTPUT and "not" a DC input fuse. That is an 8 amp 250V slow blow fuse.
Mar 23, 2010 | Vector Maxx SST Power Inverter
I replaced blown fuse with AUSTRALUX DA205-2A 2A 250V fuse for my Vox AC30cc2x. It blew after a couple of minutes in warmup mode. Have I used the correct fuse?
It's drawing too much current, make sure you install the excact replacement or an alternative approved replacement. Other than that, if it's still blowing the fuse than theres an overcurrent condition in the system...meaning a short.
Nov 21, 2009 | Audio Players & Recorders
Ka5010 amplifier dead
possibly transistor Q24 may be faulty,replace Q24 plus the associated cmponents that have blown.
Jul 30, 2009 | Kenwood Audio Players & Recorders
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Aug 03, 2008 | Belkin TuneBase FM (F8Z049-BLK) Car...
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Toshiba 37AV502U 37 in. LCD HDTV Logo
852 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
