Cameras Logo
Posted on Sep 02, 2010
Flashing orange triangle on usb when charging. No charging taking place New battery inserted and used successfully When battery flat, problem repeated itself. Don`t know if problem is the plug charger, usb cable or inside the camera Please advise.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
163
Points
Mine did this too. It's a warning to say that your battery is faulty and needs replacing , I replaced mine and It now works fine , charges fine and operates ok. You just need to replace the SLB-10A for another battery of this kind and It should be okay. Charge it overnight and in the morning iot might be ok , if not then you have another malfuntion , so take it to the camera shop for them to check or send away to samsung for repairs.
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 • Cameras
1helpful
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
1helpful
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
7helpful
4answers
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Inspiron 6000 flashing orange light for three batteries. I took apart two, made one using three groups of three cells that were fully charged and rebuilt another with brand new cells, and both get the...
The flashing orange LED is a Battery Critically Low indication.
If the Windows Battery Meter and the BIOS do not show the batteries charging then there may circuit problem in your battery.
If you can, try battery in another system, if you can't, I'd try a new battery before doing any hardware changes to the system
Charging problem
try to change the battery.........
4helpful
4answers
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
2helpful
3answers
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
When I try to charge the battery the light just flashes and the charger does not work.
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
