Question about Geneva A13 Watch for Women
HOW DO YOU REMOVE LINKS - Geneva A13 Watch for Women
  • 842 Answers
Thanks for contacting FIxYa.
I dont know what A13 is. I cant find that style #. But I can send you a link that has the most basic types of links on watches.
http://www.webwatches.co.uk/how_to.htm
Best of luck,
Jewel
Posted on Sep 03, 2010
6ya staff
SOURCE:
Band is too big. how do i remove links?
mcdevito75 here, generally the links are held together with pins, for this you"d need a link remover tool, Best Bet is to have a small watch repair shop remove these links, hold onto the removed links in case you need them again.
Feb 11, 2011 | Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
I am trying to remove 2 links from a ladies indiglo watchband
mcdevito75 here, To remove the links from any watch band requires a special tool called a Link Remover tool, available on ebay. You can remove the links without the tool but the time and work, just isn"t worthit, even with the tool if you don"t know anything about watches, your best bet would be to look for a small watch repair shop in your area , and have them remove the links, hold onto these links in case you need to ever replace them.
Aug 26, 2010 | Timex 2J611 Watch
How do I take out links on a expansion band?
mcdevito75 here, An expansion Band, if it is the scissors type band you may not be able to remove links, anyway to remove links you need a special tool available on ebay called a link remover tool, Best Bet, find a small watch repair shop in your area and have them remove the links, the cost of the shop doing it and getting the tool even off ebay is about the same.
Jun 24, 2010 | Watches
Remove links, too loose on my wrist
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to add or remove links. Rate me, please.
Mar 31, 2010 | Kenneth Cole Swiss Round Rose Gold Plated...
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Remove links
It really depends on how your watch-strap is designed. If it is a rigid one with arrows on some of the links, you may find the answer here:
remove links
There are other models with links held together with small split-pins. You have to push them out in the direction of the arrows as well. This works fine using a sewing needle with a broken tip.
Aug 02, 2008 | Timex 27191 Wristwatch
Remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
May 12, 2008 | Luminox Navy Seal Dive 3204 Wrist Watch
Remove links
i would use a bobby pin to push one of the connecters on each of the links through. remove however many links you desire and then insert a connector back in
Apr 20, 2008 | Diesel Audio Diesel Watch
Geneva A13  Watch for Women Logo
104 people viewed this question
Top Geneva Watches Experts
Janelle Schoonover
Janelle Schoonover
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Geneva Watch Expert? Answer questions, earn points and help others
