Facebook Social Network Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not access on blackberry - Facebook Social Network
Anonymous
Level 2:
Guru:
  • Expert 200 Answers
  • Posted on Sep 17, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
200
Questions
0
Helped
32287
Points
582
Do you have the blackberry internet service activated on your blackberry if not you will not be able to access facebook using the facebook. You will have to access facebook at m.facebook.com through the browser
tip
BlackBerry Error Code
When using the <i>BlackBerry</i> device <i>simulator</i>, you can sometimes meet this Application <b>Error inside JVM</b> Access Violation Reading 0x00000000 when you try to start the simulator. Here's how to solve your problem.<br /> <br /> <b>BlackBerry simulator ERROR</b>:<br /> <br /> <ul> <li><i>Application Error <br /></li></i> <li><i>Error inside JVM: <br /></li></i> <li><i>Access violation reading from 0x00000000</i></li></ul> Open the folder to install the <b>simulator BlackBerry</b> for example: C: \ Program Files \ Research In Motion \ BlackBerry Smartphone 4.6.1 simulators \ 4.6.1.199 (8900) if there is a file called clean.bat use it. Try to open the <b>simulator,</b> and if you get Error inside <i>JVM: Access</i> violation reading from 0x00000000 error again, close to the simulator, open the installation folder again and delete all. DMP files to be installed in the folder and start the mortgage again.<br /> <br /> <b>If this fails, try the following</b>:<br /> <br /> <li>Uninstall the JDE SDK and the BlackBerry Simulator</li> <li>Reboot your PC - do not bypass this step</li> <li>Install JDE SDK and the BlackBerry Simulator</li> <li>Start the Simulator</li>
on Dec 14, 2010 • Cell Phones
Hey guys . I have a blackberry mob and it was working well . I have changed my blackberry id and then bbm doesn't work since I did that . I removed it many times and reinstalled it but it doesn't work
Greetings,
Try going to this web page :
Forgot my BlackBerry ID Password And Recovery Question
and check the last reply on the page:
Re: Forgot my BlackBerry ID Password And Recovery Question.
Start first with these please:
  • KB28685 How to reset the BlackBerry ID password using the password recovery question
  • KB32111 "The link is no longer valid." is encountered when attempting to reset a BlackBerry ID password
  • KB26361 How to change or reset the BlackBerry ID password
  • KB28111 Unable to reset BlackBerry ID password when using a BlackBerry hosted email address
  • KB28232 BlackBerry ID reset email is not being delivered to the associated mailbox
If you have forgotten your BB ID credentials AND have non-BB access (e.g., Outlook, webmail, etc.) to the email account that is currently configured to your BB ID account, then those instructions should allow you to recover access to your BB ID account.
However, if you do not have access to that email account, then your challenge is much greater, and you have a choice to make depending on your circumstances:
  1. If you have no AppWorld records that you require to retain (e.g., purchase records for apps), then simply abandon the BB ID and create a new one. To do so, however, does require a device WIPE:
    • KB26694 How to change the BlackBerry ID on a BlackBerry PlayBook tablet or BlackBerry smartphone
  2. But, if you do have AppWorld records that you must keep, then you require human intervention. To receive that, you must ring up your mobile service provider and convince them to escalate your case up to BlackBerry. Further, you must convince BlackBerry to provide you with a solution -- which likely will either be resetting your current BB ID so that you can again access it or having you create a new BBID and they will manually move your purchase records over. Note that I have no idea if they will be willing to do this, but there is no other way that I know of to retain your prior AppWorld purchase records.
Deleted whatsapp from my BlackBerry z10 how do I reinstall same
You have two options.
Use a WiFi service, either at home or free at a mall. Access the Blackberry app-world site. Select apps, free or type in WhatsApp and download the app to your Blackberry. It will reinstall on your phone.
The other is to access a recent backup you had done using BlackBerry Desktop Manager and click the restore option. When prompted, click yes.
Sep 05, 2014 • Cell Phones
I am trying to manually program my Blackberry 8130. When I go to options it does not have a network setting in it. So how would I do it. Thank you Pattie
You can reset your blackberry phones then try to access that option again, if still have same result, Unlock your blackberry network using blackberry pearl 8130 unlock code. It should be unlock your network and you can try to access that option again. If your unlocked blacberry network still have same problem, go to final option to reflash your phone.
Accessing 7105t Blackberry e-mail on a PC
No unfortunately it is pushed technology straight to your device.
If you get another blackberry you can transfer your email accounts to the new blackberry retaining use of the mail account
Blackberry pearl
when you sync your prgrams on the desktop, click and drag it ouyt of the memory card and onto blackberry
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
