2002 Yamaha TT-R 250 Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2006 TTR-250 with nomods and only 200 miles on it. Like another owner, I have problems running except on choke and have seen the pipe glowing red at idle. The bike has always been hard starting. On choke or not, warm or cold, the bike surges and stalls at slow speeds but does not die entirely before coming back to life. When winding out at higher RPM & speed, the engine makes a more of a two-stroke sound and falls off the power curve. I use only premium gas and add stabilizer but no impovements. Its either fuel problem or maybe a spark but spark does not explain the surging, just the die out. Hope someone may have some insights, I'll try the carb cleaner but my gut tells me its more Thanks for your help
Danny
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Sep 05, 2010
Danny
Expert
Level 2:
Scholar:
Answers
127
Questions
Helped
55150
Points
318
Well the glowing red header pipe and the fact that its hard to start is a pretty good sighn that your VALVES need adjusted.on a four stroke bike you have to adjust the valves about every 6 months to a year( and more often if you run it at high RPMs alot) i have both 2-strokes and 4-strokes bikes and have had this same problem with my 4-strokes(honda&yamaha) if you get a manuel and are somewhat mechanicaly inclined you can adjust them your self but if your not, i would take it in and have it done because if not done properly its easy to bend or break a valve( and i think yours has 4 valves.2-intake and 2-exhaust) And head work is not cheep!!!! but a adjustment on the valves is!!!!! good luck....
2006 CBF 600 S ABS: Found patch of oil about 2.5cm diameter directly b...
this might just be oil from when you lubed the chain..dont worry! feedback would be appreciated.
2helpful
I just rebuilt my motor on my yz250f and the pipe is still glowing red what should i do?
Thats a sign of being rich, keep in mind that all of my four strokes will glow red at the header pipe while the choke is on.
Idles with choke on - dies immediately with choke off
check air bleeds in carb next check exhaust port and pipe may be clogged as well as air intake
4helpful
3answers
YAMAHA TTR 250 cherry red exhaust
Because the timing is off. If the timing is too advanced, or too retarded, it will make your exhaust pipe cherry red.
2000 ttr 250. starting problems
i u replaced your fuel filter could be clogged or dirty
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
