E-Machines (T2958) PC Desktop Logo
Posted on Sep 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Howdo you restore to factory settings e-machines laptop
Zelna
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 27, 2013
Zelna
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
362
Points
Well. Guess what. None of the solutions worked and I just thought I'll try to connect a USB mouse and there it works 100 %. Thanks for everyone that tried to send solutions.
Vareishing Maza
Level 3:
  • Master 573 Answers
  • Posted on Sep 04, 2010
Vareishing Maza
Master
Level 3:
Answers
573
Questions
0
Helped
107605
Points
2365
It is important to know the difference between aSYSTEM RESTORE or SYSTEM RECOVERY . Restoring your system to a previous date when the computer worked fine may do the trick and to do this click start, click help and support and under Pick a Task, click Undo changes to your computer with System Restore, Follow the instructions on the wizard.
A more radical remedy may be required when your hard drive will not boot up, or when you can't get the computer to navigate through the windows you need for a restore point reset. This radical resetting of the computer is called a system recovery (not a system restore) This will put your computer back to factory settings but you will lose any files you had like pictures, music and word documents.
ASUS = F9
SAMSUNG = F8
If the operating system becomes corrupt, or if the computer is hit with a virus, the best solution is often to restore the computer and reload your applications.
Click here for other option
All the Best!
Computer factory reset restore
backup your important information on your machine.
power off your unit
press and hold alt key
power on and press F10 multiple times - this will bring recovery partition on your unit. Follow steps and restore to factory settings
Hp pp2180 laptop
HP Recovery Manager can be accessd from the Start Menu, or by tapping F11 key as soon as you power on the laptop. Recovery Manager is used to reinstall back to factory specs_also used to make a Recovery Disk set.
Need to restore my laptop to factory settings.
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Heey i cant get in my laptop i changed it and i idk how to get in it. i cant think of any password it might bee cannnn uuuu plzzz heeelll[p me
Hi and welcome to Fixya!
There's no way of retrieving the password if you've forgotten it. You could only restore the machine to factory settings and start over again. Just follow this instruction and you should be ok -
When you turn the machine on, as soon as the very first screen appears press F11. It should take you straight to factory restore settings.
Restoring the machine back to factory settings will erase all changes (including personal files) on the machine so its better that you backup your files all the time.
Hope this helps!
Takasashi
1helpful
2answers
How do i reset my acer aspire to its factory settings
Hi and Welcome to Fixya!
To restore your machine back to the factory settings, just follow the simple step mentioned below. Be sure that you've backed up your personal files though before doing this because resetting your machine will wipre out any changes you have made on the machine.
For an Acer machine, just press Alt+F10 when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the on-screen instructions and you should be good to go.
Hope this helps!
Takasashi
I have forgotten my password for my computer what do i do now?
Hope this helps!
Takasashi
Need to reset factory settings to wipe laptop clean but dont have a disc
hi
there is two ways to do it.
Laptop Recovery Instructions
If you cant boot into windows
1. Power on the machine
2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click "Restore to Factory Default Settings"
4. Click "OK" to continue
5. From here, the eRecovery process will update all the data on the C: drive
and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
How do I restore my acer to orginial factory settings?
Hi!
Before restoring your machine to factory default please make sure that you mback up all your program and files to any external device.
Please follow the step by step procedure to restore your machine to factory default.
1. Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
2. Detach any external hardware such as an external hard drive or printer.
3. Press the Power button to boot your Acer laptop.
4. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
5. Select "Restore System from factory default" in the Acer eRecovery Management window.
6.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
7. Click "OK" in the notice window to proceed with resetting your Acer laptop.
8. Wait while your Acer laptop is reset to factory settings.
Should you have any other questions please just leave a comment.
Cheers~
1helpful
Factory Settings Restore for my Laptop
you can actually make a system restore disk, through the help panel. click on the start button click on help , type in system restore disk, and follow those instructions.
got backup for your E machine?
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
